Author Topic: Where can I find information on an old Rifa capacitor to find modern replacemen?  (Read 521 times)
BILLPOD and 2 Guests are viewing this topic.
Offline Aston01Topic starter
I am attempting to replace a broken Rifa capacitor but likely due to its age I can't find any documentation on this specific part number (PME 2616 MA 510).
Does anyone know where I can go to find enough information to cross-reference to a modern replacement?
Offline fzabkar
https://file.elecfans.com/web1/M00/20/FE/ooYBAFmk4f2AOsh6AFozsxcyW-I075.pdf
MP = metallised paper
    Capacitor Name - PME2616
    Capacitor Type - General Purpose
    Replacement Type - PME261E (page 42)
The following users thanked this post: Aston01
Offline David Hess
  • DavidH
MP is metalized paper.  Any y-class capacitor with the same capacitance and voltage rating may be used.  If it was a line to neutral application, then an x-class capacitor may be used instead.
Offline Gyro
Congratulation on catching it before the Rifa madness set in - they are metalized paper and notorious for giving off lots of magic smoke and occasionally a small flame when they reach a certain age. The cracking allows moisture ingress, which is the ultimate failure mechanism.
PME2616 capacitors are still available to this day, now under the Kemet brand, which will normally give several decades of continued life.
In most applications, a metalized Polypropylene (MKP) is a suitable replacement. As regards sub-type, the capacitor's position in the circuit is important, so it isn't possible to give an exact recommendation. If the capacitor is being used as an EMC suppression filter in an across-the-mains application, then it is important that a class X type is used, normally an [Edit: X2 X1 to match 630V DC rating], as they have thin metalization and are designed to be self healing on voltage spikes. If, on the other hand, it is being used somewhere inside the equipment, on a DC rail or pulse application, then it is important to not pick an X type because a thicker metalization is needed.
« Last Edit: Yesterday at 05:30:50 pm by Gyro »
Best Regards, Chris
Offline floobydust
The Rifa's have oddball lead spacing which makes changing to a better brand, a bit of hassle sometimes.
OP you have to know what class, where the cap is- across mains or to GND, used in TRS-80 etc. ;)
PME271 datasheet and PME271M510MR30 edit: not high enough voltage rating is X2 LS=15.2mm but a 15.0mm fits.
It's the LS=20.3mm parts that are a hassle to stuff in a modern 22.5mm part.
I use Epcos, Wurth, Kemet R46 or R47 R474I210050A1K is X1, 440VAC/1kVDC $0.48 etc.  Some Kemet parts have long leads if you need that.
Online wraper
  • Country: lv
Just avoid using any Rifa/Kemet paper capacitors. There is no info they were ever fixed. I know for the fact they were bad for decades, and IME capacitors made in mid 2000s were already failing in mid 2010s. Have not stumbled on these caps made 2010s so cannot definitely say anything about them but why use sus parts when there are so many polypropylene and polyester alternatives.
Offline floobydust
The paper Rifas are for sale even today, and after I'd emailed and gave them (new owner Kemet) shit over the caps failing. Wima obsoleted their version of paper+epoxy.
I think they became a magical unicorn part with their use in EMI filtering. No idea what SRF is but this might have helped, or paying to recertify EMI on a product is simply too expensive so use the old part?
I wonder what Schaffner is now using in their EMI filters, less smoke please.
Online wraper
  • Country: lv
They are a magical unicorn in a sense that no other caps fail with these audio-visual-olfactory special effects.
Offline floobydust
They are self-impregnating- just sitting there they get prego and bulge and get bigger... leading to epoxy cracking... then... birth of a unicorn does make sparks, smoke, a bit of flame.
Paper is still an excellent dielectric in some situations and is used in substation transformers, or guitar amp (paper in oil) capacitors, it can take the oil immersion.
Offline David Hess
  • DavidH
There are some X and Y class capacitor requirements that metalized paper capacitors have an easier time meeting.
It is being used in a sewing machine pedal (wired for US Style 110v). I have tried to find a wiring schematic for the pedal but as of yet no luck.
I noticed in other parts of the machine there were X/Y type caps used and explicitly labeled as such but this one has no obvious designation as either type and even the Kemet catalog segregates them into a General Purpose category (screenshot attached).
Anyone able to clarify why something not noted as an X/Y type would be replaced with such?
BTW - Thanks for all of the information so far... this is an extremely common question for this machine on just about every YouTube video and NO ONE actually identifies the modern replacement.
« Last Edit: Yesterday at 08:02:06 pm by Aston01 »
Offline floobydust
What make/model sewing machine is it? I did draw a few schematics of these, Elna Stella Air? and some other one.
What do you measure for lead spacing? The PCB has extra holes to take two different size parts. How much room (height) do you have for one?
The part I linked to in post #4 is higher voltage 440VAC X1 and 18*5mm, 11mm H and leadspacing 15mm.
edit: it doesn't look like an X-cap application, two high value resistors are in series with it. The EMI filter caps X, Y are in the potted module.
The black blob looks like a MOV.
« Last Edit: Yesterday at 08:26:32 pm by floobydust »
Bernina 830 Record Electronic
Lead spacing = 10.2mm
Original Cap height of body = 10.2mm
The enclosure looks like it has room for up to 14mm of height if there was some reason to go to a taller body.
Online DavidAlfa
You'll find 10nF 630V mkp/mkt (propilene/polyester) capacitors anywhere with the same spacing or close enough.
Just search 10nF 630V, anything square with leads will be one of those, usually blue, green, yellow or red.
« Last Edit: Yesterday at 09:29:47 pm by DavidAlfa »
Offline floobydust
Consider PP 0.01uF ±5% 630VDC LS=10mm, size 13*4mm height 9mm. Not an X-cap application here. It might be doing timing so I'd use a 5% tolerance. This is a common part:
https://www.digikey.com/en/products/detail/epcos-tdk-electronics/B32621A6103J000/592902
https://www.digikey.com/en/products/detail/kemet/PHE450MA5100JR05/3465857
https://www.digikey.com/en/products/detail/kemet/R75PF21004030J/5731245
