Author Topic: Brüel & Kjær 2801 Microphone Power Supply Schematics  (Read 1101 times)
Offline SmokyTopic starter
« on: January 08, 2024, 05:13:07 pm »
I'm hoping that someone might have a copy of the Brüel & Kjær 2801 Microphone Power Supply schematics.
I put together the 2801 microphone power supply, the 2615 cathode follower microphone pre-amplifier, and the 4134 microphone for a test.
I'm measuring 14.5v of DC after the internal 4uF blocking capacitor at the direct output. I measure 62v of DC before the blocking capacitor (signal path from the microphone).
When I speak from a distance into the microphone, I do get between 0-10mV of AC at the output.
Online timop
Re: Brüel & Kjær 2801 Microphone Power Supply Schematics
« Reply #1 on: Yesterday at 09:26:11 pm »
I have a service manual for the B&K 2803 two channel power supply, dated from 1967. The circuit might be quite similar to the 2801 (block diagram attached).
If you're still interested, I can scan it and make it available after returning from my summer holidays in a couple of weeks.
BR, Timo
