Author Topic: Huntron Switcher 640  (Read 746 times)
Offline Martin MirandaTopic starter
  • Country: ph
  • ~~Work: Electronics~~, ~~Hobby: Electronics~~
« on: January 06, 2022, 03:08:33 pm »
got this equipment for free, got really excited that it would be like a huntron tracker. when i got home i realized it has a LCD instead of the usual CRO or LCD screen.... upon a quick google it's a extension for huntron trackers for "automating", and no amount of google fu that i can find the service manual or schematics.
so i took a look at the schematics of huntron tracker 2000 instead. and how it feeds signal to the switcher.
upon closer inspection it uses a 8051 mcu and a ADC...  the tracker only sends the sine wave and a ttl output clock. making me think that this is a independent machine. (so i fed in a 60hz 7.07 Vac rms signal) the sync from the signal gen to the clock input. and it worked!  :scared:
« Last Edit: January 06, 2022, 03:19:57 pm by Martin Miranda »
beach, sun and the island i call home.
https://www.youtube.com/channel/UCOspWWciGGyF5NwmeVT_mWA
  • Country: ph
Re: Huntron Switcher 640
« Reply #1 on: January 06, 2022, 03:14:18 pm »
- power is supplied by the huntron tracer... split 12vdc.
- clock is mentioned in the manual that feed to the switcher.
