Another nice easy one, I use an Agilent 8935 Communications Test Set as part of a production test jig, they're old, circa 2000. They work well, are usually reliable, and are cheap on the second hand market. They're also built like tanks.
Today I came to use it, switched it on with the rocker switch, but nothing happened, no life at all. I checked the fuse and integrated GFI, all good, and power was getting in somewhere as the GFI trip test worked when plugged in.
Problem with these units is that there are tons of screws to facilitate disassembly, but thankfully they're almost all the same T20 screw.
The internal standby LED was working but no other supplies.
It turns out it was the rocker switch, rated at 10A 250V, but judging from the wires on the short cable harness this is a low voltage, low current soft connection. Sure enough it was the switch, I could switch on the unit by shorting the connections.
Expecting to need to order a new one, I had a look in the switch drawer and amazingly I actually had a small stock of fit-ready replacements, albeit black rather than white.
