Author Topic: What kind of flex flat cable is this? (for resistive touchscreen assembly)  (Read 849 times)
Offline nautTopic starter
Hello,
I have a Cowon-D2 mp3 player and the flat ribbon cable (4 signal lines) that is connected to the resistive touch screen assembly has cracked, (shown with the red line) on the attached pic.
Does anyone know what kind of flat ribbon cable is displayed in the picture?
Or perhaps what resistive touchscreen overlay assembly model it is? The small text on the bottom reads "atouch ao25-3d e8". But I could not find such a touchscreen module.
Thanks!
https://www.cnet.com/products/cowon-d2/specs/
https://ae01.alicdn.com/kf/HTB1n4vhzRyWBuNkSmFPq6xguVXaD.jpg
« Last Edit: July 01, 2019, 05:28:00 pm by naut »
Online coromonadalix
« Last Edit: July 02, 2019, 01:11:09 am by coromonadalix »
Phewww... It took me a while but I've fixed the cable. Not sure how long it's going to hold so I've ordered some 4 pin 1.0mm pitch flex cables just in case.
Thanks for the links. I've seen the whole display assemblies but it's overkill in this case. As far as the overlays, I was not able to find out exactly the one that would fit the display module.
Offline Nerull
Pretty sure that isn't a cable, its a flex pcb.
Offline wraper
  • Country: lv
It's FFC (Flexible flat cablehttps://en.wikipedia.org/wiki/Flexible_flat_cable. Carbon traces on kapton substrate. Often also called FPC cable (flexible printed circuit) although it's technically not correct as there are no components.
