Hi,It seems to me that by multiplexing we are talking about dynamic LCD indication, as can be seen on the example of the Xerox 600T1616 DMM circuit.As you can see, the MITEL MD4330B shift register is used.In your case, you can use ICL7136 because it works with LCD and can replace ICL7106.https://www.renesas.com/us/en/products/analog-products/data-converters/analog-digital-converters-adc-precision/integrating-display-output-ad-converters/icl7136-3-12- digit-lcdled-low-power-display-ad-converters-overrange-recovery?utm_source=supplyframe&utm_medium=SEP#overview
For my understanding it's a non-multiplexed LCD (every single segment has its own pin for contacting).
