It's UC3843 or it's clone. There is no way to reliably test it without applying power to it. You can try measure it's mosfet driving output resistance to the GND, if resistance is low, it's 100% dead. From experience, it has 90+% chance to be faulty anyway. When mosfet fails, usually it applies high voltage to IC output through it's gate pin.
