Ok. Card died. I sent it in service and there was mudman working. He broke attachment slide, cooler plastics and overheated the gpu. He was suppose to check two cards and tell if he could fix em. I told not to start without permission. The place was in Finland, Helsinki, Vuosaaren ATK. Too bad service! The guy took apart another card totally, so now it's not even fixable.
So I got another one to be fixed. There seems to be just some BIOS problem with this one. I allready got a BIOS pack for R9 290 from Sapphire and now im seeing a card with U2 and U3 BIOS chips. I just don't know which one goes with 'Silent' -mode and which one is with 'Über' -mode, so could you guys tell which is which. BIOS files for my 102-C67111-01-AT is 28PA500.SB5 (64kb) and 28PA500.UB5 (121kb). Switch at vga connector side is suppose to be 'Silent' -mode and 'Über' at power connector side.
I use extented programming clip, so I just need to know which BIOS for each.
