Hello. Vacations, work and other work around the house have gotten in the way but I have now narrowed down my issue to the A7 YIG Loop board.
It turns out that the A7J1 input (from the A4 Coarse Loop) goes deaf for frequencies over 300 MHz or so.
At 4000 MHz RF out, A4 outputs 212.641MHz/-0.86 dBm - A7 locks OK.
At 4100 MHz RF out, A4 outputs 414.003MHz/-1.42 dBm - A7 fails locks. Same for higher A4 frequencies.
With A4 replaced by external signal generator 414.003MHz/+5 dBm - A7 locks OK.
The service manual states that the A4J2 output should be 0 dBm +/ 6dBm, so my A4 seems okay. The A7J1 input must be deaf.
Now, unfortunately, the only A7 YIG Loop board I have found for sale is way too expensive. That is half of what I paid for my 69147A.
https://www.ebay.com/itm/145987476741So my next step is to take my A7 apart and try to trace out the schematics.
Then, try to identify what part possibly could act as a low-pass filter on the A7J1 input.
Per attached block diagram, could also be an issue with the SRD (Step Recovery Diode) or Sampler?
If anyone happen to have a A7 6800-D-40627 Rev C board for sale, please let me know.
Thanks,
/John.
