?? Does any one have a Spare ADC plastic socket for the 54845 with pogo pins ??
I think I have located one problem:
I have one damaged plastic ADC socket, with missing Gold coloured pogo pins (I have the 4+2 screws removed, & the 2 metal sandwich parts removed & the white ceramic part removed).
So, I need to get a socket or try to repair the existing socket that has missing pins & springs.
How does one R&R the Pogo pin socket ?
It looks like there are some small steel guide pins holding the socket onto the ADC PCB?
>>>>Example showing the ADC chip removed & the plastic pogo pin socket removed from the PCB.
>> How does one remove the plastic socket at that level ??
see the photos #9 & #10 in the EEVBlog July 8, 2017:
https://www.eevblog.com/forum/testgear/agilent-54835a-scope-(4-channel-1ghz-4gss)-repair-uphack/Does any one have a spare 54845a ADC socket !
thank you,
