Hi
0K I was dealing with the after effects of a TBI at the time and I found fault finding was therapeutic. I couldn't assemble a plastic model F1 race car, but I could fault find 80's vintage electronics.
I built an NVRAM programmer to read/save/write the contents to the new NVRAM module. I think I wrote this up.
I don't think it helped because my NVRAM was so old, I wouldn't rely on the memory still being intact.
I'd suggest you do some hardware debugging around the cal mode switch signal. If you want me to run a duplicate test to spot diffs, let me know. If you don't have the manuals get them.
I don't think the NVRAM holds code. I suspect a blank NVRAM is filled with default values, then over-written in the cal process. That would be a period correct approach because it would make manufacture easier.
I did suspect the NVRAM held code because the phase modulation feature on my SG didn't work, then it did.
I did a cal on the SG amplitude output and got it to within +/- 0.1dB. By modern standards the harmonics are not great but good enough for most work.
Do you have the manual? It shows how to run a bunch of built in test procedures that look like they were designed to be used on the production line for fault finding.
Did you use the same blue colour backlight? It looks very cool.
