Hi All,
I'm currently repairing a DJ light which uses two voltages, a 12v and 28v supply.
Currently, a couple of the steppers on the 28v side aren't working at all and I've been swapping chips for a few days to no avail.
I've just noticed that the 28v side is being pulled up to ~31v. I've checked another unit and it doesn't do this, I've also checked with a known good supply to make sure it's not that either.
So I'm a bit puzzled, could this be a shorted component? Any suggestions as to what would cause that?
Picture attached of the board. The 28v is the brown wire and supplies the LED circuit, and two of the steppers controllers.
Thanks!
