ok I fully tested it. Not a single problem to report, I am a happy camper!
What a nice device, definitely my first choice as my daily work horse!
Upgraded to last FW went well, and no need for calibration it was bang on.
I report here below what AIM TTi support told me to do as sanity checks as first step:
1. Measure the 5 sub-main fuses as marked in the first image on the reverse of the board. Can be easily checked due to the power board on the right hand side of the unit.
2. Measure across the two outside legs of Q11 and check for a reading of 100K.
3. Measure across the two outside legs of Q12 reading should be high and not low.
4. Power the unit and measure the voltage rails on the top right hand side of the board where the large cap is and ensure the +5,-5 and +7V5 rails are active.
What killed the ADC? My guess is an ESD zap from the outputs.
