So, i have recently acquired the 123b Scopemeter from Fluke, and I was under the impression that this scope was channel isolated
Well, I was probing two MOSFETs in a charger circuit to check if they were gone. The control circuit is modulated by one of these transistor. I first probed the gate, and the incoming signal was about 0.2V on both.
Probing the drain, with common ground on both channels caused a short circuit. I havent measured the resistance of the ground probes before, again, because i was under the impression the unit was isolated. I sent a test signal into both channels and they seem good. But the thing worrying me now is that i only measure 160 ohm over channel grounds and 80nF. Are they isolated.
I now realize that the high frequency over a cap can cause the short and should have used a differential probe on the second channel.
Anyways. On my 124 Scopemeter the ground channel impedance resistance is 0.8kohm.
Can somebody please explain why i am seeing so low values on isolated scopes, or are these not isolated?
