Author Topic: Agilent E3632A "Repair"  (Read 1519 times)
Offline juroTopic starter
  • Country: vn
« on: August 24, 2021, 04:39:36 am »
Hello everybody.
I'm Khanh. i come from Vietnamese.  I'm fixing my Agilent E3632A.
 There is 1 problem with "led panel" IC U7 - EE8051BH is short circuit VCC- GND.
I hope someone can show me where i can get U7 firmware  or read U7 firmware and send me a coppy.
Thank you.
Online chekhov
  • Country: by
The following users thanked this post: juro
  • Country: vn
Re: Agilent E3632A "Repair"
« Reply #2 on: August 25, 2021, 04:15:06 am »
Chekhov, thank you for your help. I will try but I don't think E3646A will work with E3632A.
Offline kjk24
« Reply #3 on: September 04, 2021, 11:37:34 am »
i have exact the same issue, i replaced the Ic with a AT89c51RC2 with the Firmware n80c51bh_E3633A_Display_Board from a nice member here in the forum (thank you for the file) , the Tool what i used for flashing is Flip from Microchip "FLIP 3.4.7.112 for Windows" with Serial programming on a breadboard.
i tryed to programm it with a TL866 Pro a brand new and a older Version but it wont programm it? i dont findout why.
maybe someone have a Agilent E3631A file for me?
my Display CPU wars also short (and hot),
the display is now dark and the PS beep one time if i switch it on, 5V on the Displayboard are ok.
Replaceing the Display driver IC not helped.
If a Button is pressed sometimes the unreg. will light thats all what it dose.
The unit Selftest (switchon with button pressed) do nothing
The Bias Supplies on my are ok.
1262665-0
the Display get IGFPSCK 8Bit clock packages one per second or so from the Main CPU and the display answer with some data on
FPDO. But no IGFPDI and no IGFPINT signals, U8 looks ok
Have you more ?
regards
kai
« Last Edit: September 05, 2021, 07:44:10 am by kjk24 »
best regards
kai
I7 &
E4 1.19.8
Offline kjk24
« Reply #4 on: October 31, 2021, 04:10:42 pm »
after a while i repair'd the unit, defect wars the RAM chip too.
before changeing the RAM i replaced the CPU, the eprom without succes.
best regards
kai
I7 &
E4 1.19.8
