Author Topic: Invertor 48V /220V  (Read 601 times)
Offline JaneTopic starter
Invertor 48V /220V
« on: July 12, 2024, 08:16:07 pm »
The invertor has  2 air fans that start only  when quite a high electricity consumption is needed . Otherwise the fans are  quiet. It worked that way for about 2 years. Now,however, the  fans work all the time.
On the enclosed pictures you can  see   a   region   where fans are connected. It seems quite simple. Anyone knows the principle , how the  fans are controlled?
Thank you
Offline Kwakerman
Re: Invertor 48V /220V
« Reply #1 on: July 13, 2024, 10:00:36 am »
Looks like you have a temperature sensor attached to the heatsink (first picture top heatsink).  Might be for overtenp protection or fan control (or both).  Suggest you try and find a circuit drag for it.
« Reply #2 on: July 13, 2024, 02:44:46 pm »
Thank you for the reply.
Can you please mark in the picture where do you think there is the sensor?
Offline voltsandjolts
« Reply #3 on: July 13, 2024, 03:49:09 pm »
It's here:
Offline johansen
« Reply #4 on: July 13, 2024, 06:29:51 pm »
the traces on the board run all the way to it.
looks like the fans get power from a rectifier and aux turns on the transformer.
Offline Vovk_Z
  • Country: ua
« Reply #5 on: July 15, 2024, 10:20:44 pm »
Yes, fans get power from a main transformer. The higher load the higher FAN voltage. But there possibly is BJT transistor which controls swit hing on and off of a FAN. And possibly it became shorted.
Offline coromonadalix
« Reply #6 on: July 16, 2024, 08:09:49 am »
yep i would have said the same thing,  come from the main ac voltage then rectified as DC, a crude way to make them work ... and they are 2 wires only ...
the thermal sensor should be used in the main controller section
Offline BrokenYugo
« Reply #7 on: July 16, 2024, 02:11:48 pm »
From the pics I would guess transistor Q33 is either shorted or whatever can turn it on is.
