Hello,
I'd like to reuse this 1 phase ROTAZ 230VAC 100W inductor motor, but have no idea how its two coils (oposite each other with inductor rotor between) are wired inside and what could be external simple circuit to drive this quite nice fan
Measured resistance between all possible two of its four (W)hite, (G)ray, (Black), B(L)ue wires combinations and got something like this marked also on its attached photo:
Rwg: 17 R
Rwb: 34 R
Rwl: 42 R
Rgb: 17 R
Rgl: 59 R
Rbl: 76 R
If you have some suggestions how to wire this thing to get it working again @ nominal 230VAC please let me know, while those bloody 1 phase AC motors are not I used to drive on daily basis, while prefere nice 3 phase AC motors and wouldn't like to do any teardown of this thing to look how it is wired inside since it's in a very good shape.
Note: There were no additional capacitor, just 230VAC mains wires and multipositional switch with b(L)ue wire cracked disconnected...It is from unknown source on local market... no idea if it were other components with this motor.
Ancle
google says nothing about ROTAZ fan
This is not anything similar to this what I've got for $2
http://www.tradeindia.com/fp983306/Rotaz-ID-Fans-Cement-Mill-Fans.html
