Author Topic: (Another) Troubleshooting a Yamaha receiver with DC_PRT (protect shutdown) probl  (Read 9747 times)
Offline alanep
FYI, Q1105 and D1081 test out OK
I'm being a bit pedantic, did that test also include D1080?
Maybe check D1080, D1081 as well.
« Last Edit: January 26, 2023, 08:01:19 pm by alanep »
Offline NHcoderTopic starter
Yessir, my mistake for being imprecise.  I checked both, both are good.
Short update, the replacement transistor arrived today at last.  Installed and checked, weird output channel DC voltage is gone, so I'm starting the reassembly.  Hopefully all goes well, so many wires and screws to put back in now.  Fingers crossed.
EDIT: Bleh.  Still a no go.  I got one "I PRT" (current protection) and since then, "DC 0" again.  So maybe something went overcurrent, blew that transistor.  I'll pull it all apart and start checking things again in the next few days.
EDIT2: A little more testing today, showing -6vdc on all the outputs on MAIN(1) now.  More checks later, been busy lately.
« Last Edit: February 19, 2023, 05:47:02 pm by NHcoder »
