Author Topic: Rigol DS1054 Weird Channel 1  (Read 20261 times)
Offline AdamHerbstTopic starter
« on: April 11, 2024, 02:48:31 pm »
Hello Everyone, attached I have a photo of the inputs for my Rigol DS1054. Every channel but channel 1 seems to be working in order. Channel 1 is very wonky. What would be the best course of action for a repair? Opening up the oscilloscope probing the inputs, or could it be a firmware issue? I will be doing both, but im just wondering if someone before me had this problem and could share a little bit of wisdom.
~ Adam
Offline GGMM
Re: Rigol DS1054 Weird Channel 1
« Reply #1 on: April 11, 2024, 03:00:13 pm »
hello,
See here some small diagram tips
https://www.eevblog.com/files/Rigol-DS1054Z-Schematic-DiffAmp.pdf
https://fr.scribd.com/document/383431220/Rigol-DS1054Z-Schematic-FrontEnd
I think we need to dig there to the input
Basic thing, you did the test to invert the probes and see which are all at *10
Confirm 1054Z.
I don’t know any more
cdt
Offline wasedadoc
« Reply #2 on: April 11, 2024, 03:05:27 pm »
I doubt that could be a firmware problem.
Is it the same for all settings of CH1 Volt/div?  (Adjust input level appropriately)
The following users thanked this post: AdamHerbst
Online 2N3055
  • Country: hr
« Reply #3 on: April 11, 2024, 03:14:13 pm »
Check the probes first.  Try exchanging probe from a "good" channel first.
Probes that com with the scope are not very robust.
Offline wasedadoc
« Reply #4 on: April 11, 2024, 03:24:01 pm »
The rising and falling slopes of the displayed CH1 are different.  I don't think a fault in a passive probe could do that.  There is also delay.  Looks to me like a hardware problem in the scope.
Offline GGMM
« Reply #5 on: April 11, 2024, 04:48:57 pm »
hi,
also look at the ladders
on ch1 the signal seems to make 3v peak to peak
6v for the others
cdt
Online 2N3055
  • Country: hr
« Reply #6 on: April 11, 2024, 06:12:10 pm »
It can definitely be the probe..
It can be channel but also probe.
