original part in question is U1640G in TO-220 package and it is from SMPS so it must be ultrafast rectifier desoldered one pin and it still reads short accros 1 - 3 pins.
Perhaps you think you desoldered one pin but actually did not?
Oh, you are measuring in-circuit. Then your initial measurement was OK because often those diodes are used in parallel, pins 1-3 tied together.
