Be sure to test, or just replace, the capacitors on the +/-12volt power rails. If they are dried out, the op-amps may become unstable and oscillate, with the bop noise being the audible result. A scope could be handy to check for ultrasonic signals. As old as that chip is, it comes with 10mhz bandwidth.
