I'm trying to fix a switchmode power supply from a piece of broadcast equipment (an NTL/DMV/NDS/Tandberg System 3000 satellite receiver) which won't start under load.
The PCB bears the legend "MADE IN UK PROFESSIONAL PSU RD.S.5497PCB.D MOD 4", with "5497-0401" and "SSL9601 5497 05416" on sticky labels near the output connectors.
The issue is that it fails to start when there's a load greater than 2.3A on the digital 5V rail, but works fine below that.
The motherboard in the equipment pulls about 2.5A at startup - which is why this is an issue...
If I let the power supply start up (either no-load or with a ~2A load) then connect D5V to the motherboard, everything works fine.
When the PSU is running normally I see around 6V across the slow-start capacitor; when it's stuck trying to start up I see around 1.4V.
The satellite receiver itself works fine when tested with an ATX power supply providing the 5VD rail -- or indeed providing all the rails (with a few external regulators to generate 33V and 8V)
The PSU is a TDA8380-based thing with a bunch of output rails -- +33V, 13V/18V switchable (LNB), +12V for the fans, +8V, +/-5V analog, +5V digital.
From what I can gather, it's based on the Philips 70W reference design (
http://educypedia.karadimov.info/library/APPCHP4.pdf page 70) but an AVS1BC automatic voltage switch and triac have been added to allow it to run from 110V/230V without needing an input voltage switch.
Initial failure on arrival was a blown line fuse, bridge rectifier stage (all four diodes blown) and a blown SGSIF344 chopper transistor (dead short across all three terminals). I later found a dead 22uF 25V gate drive capacitor (C16 in the reference design) and a few more shorted diodes which were also replaced.
I've replaced the SGSIF344 chopper, bridge rectifier diodes (and some other dead diodes), the startup capacitor (C5) and the gate drive capacitor (C16). The TDA8380A was also replaced (with a TDA8380) to resolve an issue where the PSU went out of regulation after a few minutes operating (I guess it was damaged when the chopper failed).
I've also tested the other diodes and ESR tested the capacitors, all are good.
I had to replace two series diodes (A-K--A-K) which were across the current sense resistor; I've replaced these with 1N4001s but I'm not sure what they're intended to do.
If I try to probe the current-sense line (pin 13) with a DMM, the power supply shuts down and starts chirping (second-level slow-start mode).
Does anyone have any ideas why this thing might be failing to start under load, but work fine if it's started up on a lower load?
Cheers,
Phil.
