Hi everyone.
Big thanks in advance to the people who can help solve my repair problem on RIGOL DP811 (SINGLE OUTPUT 20v/10a 40v/5a).
I stupidly turned off the power supply
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
while a charging battery was connected to the output.
This incorrect operation caused an SMD current detector shunt resistor to burn out.
I can no longer read the value
![Ohms \$\Omega\$](https://www.eevblog.com/forum/Smileys/default/omega.gif)
because it has burned out...
Can anyone check its value on their power supply, or indicate and/or provide me with the electronic diagram with part list of components of the DP811.
The position on the printout is R52.
I found some photos of a teradown of DP832, (the value is 0.020 Ohm) But the value used by Rigol on DP811 is different.
I can't read the value because the current detector resistor has burnt out. Who can kindly help?
Spending $1000 on a new power supply
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
for a stupid $2 resistor is crazy.
Help!!!
Thank you
