Hey all,
I have an Ego battery that is new from this year (already got a replacement want to try fixing this one too). On the BMS, they changed to using a smd resistor or fuse marked 510 with a line over it. Package size is 1206. I opened the replacement battery and that is how I found this, I measured it and it does have a resistance of 51 ohms. I did find some fuses that have the line above for fast acting and line below for lag time. But I'm guessing that this isn't the case here since it's a 51 ohm resistor. Anyone have any idea what that line might be designating?
