Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
no trace and toasty resistors mistery
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: no trace and toasty resistors mistery (Read 479 times)
pitpat
Contributor
Country:
on:
May 17, 2020, 10:05:52 am »
I got this hameg 103 scope to be rapired since it died on me while probing the cal. trace. It works in component tester mode but not in scope mode.
After checking every components i found a bf199 transistor that was gone so i replaced it, changed the ac main to 240 ac that fixed the wrong values outgoing from the transf. and recapped all the board but still got no trace.
The only thing suspicious is the big 2w 1k8 resistor that get proper hot with some magic smoke released if neglected.
Scope schematics
https://cdn.rohde-schwarz.com/hameg-archive/HM103_englisch.pdf
Some photos of the scope fom an old tread
https://www.eevblog.com/forum/testgear/hameg-hm103-problems-repair/
what you guys think?
Thanks to all
Logged
Gyro
Super Contributor
Country:
Re: no trace and toasty resistors mistery
Reply #1 on:
May 17, 2020, 10:56:19 am »
You keep starting new threads about repairing a single piece of equipment (Hameg 103). If you keep starting different threads on the same subject, people will get fed up with cross posting the same information and just give up on you.
https://www.eevblog.com/forum/beginners/oscilloscope-tranformer-extravaganza/
https://www.eevblog.com/forum/beginners/bf199-equivalent/
https://www.eevblog.com/forum/repair/help-with-resurrecting-an-analog-scope-(moved-from-another-section)/
Use one of your existing threads and keep all the information together.
Last Edit: May 17, 2020, 10:59:11 am by Gyro
Logged
Best Regards, Chris
I wanted a rude username
pitpat
Contributor
Country:
Reply #2 on:
May 17, 2020, 11:06:26 am »
You're right I'll try to keep all about this scope in one tread from now on.
Last Edit: May 17, 2020, 11:07:59 am by pitpat
Logged
Gyro
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
