I am trying to repair a JFJ Easy Pro disc repair machine, I've narrowed the issue down to a bad crystal. Sadly it's not marked and the micro controller it's connected to either has fake markings or is a custom chip maybe? It controls the timer, the leds and the relay for the motor. The micro is marked N79A1021 and you can see the crystal next to it in the picture, is there maybe a few 'standard' values I can try? I've tried probing the bad one when it does run (heat gets it going briefly) with the oscope but it just stops running as soon as I probe it.
Thanks.
