We have a whole bunch of Mac 2000 Wash movers here all developing the same fault F1ER.
In each of the MAC 2000s the light sensor (connected to no. 41 on the loom) has yellowed over time (presumably due to the UV from the lamp over time) which I believe is the cause of the fault.
I have verified this by swapping a sensor from a working unit into each of the faulty units and they work fine after this.
The problem is I cannot identify this component?
I would have thought it is some kind of phototransistor but it has 3 pins and don't they usually have two?
Can any one shed some light (pun intended) on what this component is?
