hi, last weeks how i have some time, i begin repair two 2001.
first defect spend parts for second repair.
pcb blow up neer caps, repair pcb and caps, change relais and parts from power supply part, change all chips marked in blue!, change fan and pcb is running with many erros, but run
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
. too many party needed so i do nothing more.
defect now :transformer frontinterface, completed frontinterface (display+chips), thermalfuse (ceramic), transformer ...
offer for new 2001 with many of discount is 2600euro, needed parts cost more!
(offer for rebuild front transformer 580euro, offer transformer 960euro, offer frontinterface 1800euro)
![This Keithley 2001 IS NOW saved! 909740-0](https://www.eevblog.com/forum/index.php?action=dlattach;topic=219580.0;attach=909742;image)
second repair same, blow up caps, change many of chips same other repair (blue marked), use transformer and thermalfuse from 1. (transformer positions needs new screwhole to mount, hole now left bevor in middle of transformer , change fan ...
last error, Software 1991, A06, A01:
200.1 A/D
200.6 A/D
200.7 A/D
201.2 Testcal
412.1 ACA Switch
the 200.x are errors from firmware??
i reading her
https://www.eevblog.com/forum/testgear/restoration-glory-of-keithley-2001-dmm/500/what can i do as next step??
for test i calibrated the 2001 and runs without errors. voltage and current looks like good.
![This Keithley 2001 IS NOW saved! 909736-1](https://www.eevblog.com/forum/index.php?action=dlattach;topic=219580.0;attach=909738;image)
