Author Topic: What's the value written on this capacitor?  (Read 1671 times)
Offline azigtaTopic starter
« on: July 26, 2016, 07:10:29 pm »
Hi, I'm trying to repair a pc motherboard and I have to replace 3 electrolytic capacitors labeled "FP 13Bx 101 16" but I don't know how to read that :\  Maybe someone here can help me
Thanks
Offline Jwalling
  • This is work?
Re: What's the value written on this capacitor?
« Reply #1 on: July 26, 2016, 07:18:36 pm »
Are they aluminum types? If so, I would say 10uF 16VDC. A picture would be helpful.
Jay
Jay
System error. Strike any user to continue.
Online PA0PBZ
« Reply #2 on: July 26, 2016, 07:21:30 pm »
I think 101 is more like 100uF
« Reply #3 on: July 26, 2016, 07:25:26 pm »
Jay
Hi, thanks for the reply. Here you have a picture . As you can see it's aluminum. I also believe that is 10uf 16VDC. Can you confirm that by seeing the picture? Thanks
Maybe it's helpful to say that those 3 capacitors were located close to the I/O port usb ports. The motherboard is an Asus P8P67 rev 3.1 if that helps
« Last Edit: July 26, 2016, 07:27:21 pm by azigta »
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #4 on: July 27, 2016, 05:37:28 am »
Looks like 100uF, 16V.  Might be Panasonic FP series, but the markings don't match what's shown in the data sheet Mouser currently links to.  It may be an older cap and they've changed the markings, or it may be a different manufacturer/series.  It does look like 100uF @16V, though, whoever made it...
The marking is typically digit-digit-multiplier.  Think of the multiplier simply as the number of zeroes to put after the digits.  In your case, 1-0-with one additional zero for 100uF.  471 would be 470uF (4-7-with one additional zero), 1000 would be 102 (1-0 and two more zeroes) and 100 would be 10 (1-0-with zero additional zeroes resulting in 10uF)
It gets a little weirder when they're values with a decimal; those are typically displayed with an 'R' where the decimal point would be, thus still giving a three digit code.  For instance, 2.2 uF would be shown as 2R2, and 0.47uF as R47.
Hope this helps.
-Pat
The following users thanked this post: azigta
« Reply #5 on: July 27, 2016, 12:55:20 pm »
Hope this helps.
-Pat
Thanks, I'll replace it with 100uF 16V capacitors.
