Author Topic: The old crazy Tektronix TD 210 rotary encoder problem - solution  (Read 3099 times)
Offline PaulusthewoodgnomeTopic starter
These scopes are often flogged off cheap due to their dicky rotary encoders and the annoying trait of timebase/voltage div. settings  jumping around when trying to adjust them.
Similar forums have suggested trying to source replacement encoders from sacrificial units bought cheap but then there's the hassle of completing the transplant without causing further problems.
My old TDS 210 had a timebase encoder in this jumpy state so I ended up drilling two 2mm holes very carefully in the bottom edge of the encoder and opposite top edge using a pin vice and sharp 2mm bit.  The holes went through to empty space (see pic) and attention was paid to  ensure no swarf went in.
I then jetted in plenty of contact cleaner and exercised the encoder for a minute or so before sending in some compressed air in each hole to make sure things had evaporated off.
After this cleaning things are back to normal and I can reliably make my adjustments without relying on the lottery draw of turns that I was having to make before cleaning.
The following users thanked this post: xrunner, nouserid, mnementh, TERRA Operative
Online xrunner
  • hp>Agilent>Keysight>???
Re: The old crazy Tektronix TD 210 rotary encoder problem - solution
« Reply #1 on: October 21, 2018, 11:06:31 pm »
Interesting solution. What type of contact cleaner did you use?
« Reply #2 on: October 22, 2018, 12:05:48 am »
Hi Xrunner, the contact cleaner is a WD-40 product - 3 in 1 contact cleaner. I should add that when drilling the holes, I only just allowed the drill bit to form the hole and kept it's intrusion into the inner workings to a minimum.
I guess there's always a risk of doing damage to a component when drilling into it but the scope's behaviour was a risk to itself  and I saved it from being kicked across the room in frustration so I felt like there was nothing to lose.
« Reply #3 on: October 22, 2018, 12:16:52 am »
Thanks for the handy tip.
Online xrunner
« Reply #4 on: October 22, 2018, 12:29:42 am »
Man you need to post a lot more - you joined in 2014!  :-//
Offline xavier60
« Reply #5 on: October 22, 2018, 01:53:25 am »
I find that Pots, mechanical rotary encoders and tactile switches are less likely to fail again after a suitable lubricant is used.
I have good results with synthetic PAO oil.
It is commonly available as compressor oil.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #6 on: October 22, 2018, 04:24:15 am »
Deoxit fader could be good for this application.
A bit of tape ove the holes could be good to keep dust out in the future too.
Online shakalnokturn
« Reply #7 on: October 23, 2018, 07:56:58 am »
Nice trick, I've used contact cleaner before on one of my Lecroy 9300's, that uses similar Bourns rotary encoders.
In my case there was enough play in the axis to let the spray flow down it.
A couple of side notes:
Protect your eyes when spraying into small holes, I once sprayed into a small DC motor at the  brush holes with contact cleaner, quie a proportion flew back at me and  cleaned my eye. That was painful and stressful for several hours
On cheaper rotary encoders and potentiometers as found in much (Wun Hung) Lo-Fi audio equipment where the grease just turns to stiff goo, white-spirit before contact cleaner works wonders to ease the rotation.
Offline rf+tech
  • Real radios are olive drab
« Reply #8 on: October 23, 2018, 01:03:49 pm »
A non-invasive technique that I use successfully, gets Deoxit into such places, by putting physics to good use.
Preload a small amount of Deoxit into a syringe.
Warm the component body to expand internal air.
Using the syringe, apply a few drops of Deoxit to the shaft bushing.
Deoxit will be observed to flow into the bushing/body, as internal air contracts.
Place part in freezer for a few minutes to accelerate the process.
Two or three cycles has proven sufficient.
RF+ Tech
RT-1133 AN/PRC-70  *  RT-794 AN/PRC-74  *  RT-841 AN/PRC-77  *  RT-524 AN/VRC-12  *  RT-834 AN/GRC-106  *  RT-F100
« Reply #9 on: October 23, 2018, 02:24:28 pm »
Thats a real crafty and neat solution that leaves zero evidence behind that you've in there as well, neat.  :-+
The following users thanked this post: WattsThat
Offline nouserid
« Reply #10 on: April 25, 2020, 02:49:25 pm »
I too have my TDS2014's encoders fixed with CRC contact cleaner (a no residue solvent). Instead of drilling a whole on the encoder body, I noticed that there is a tiny gap between encoder casing and PCB. Spraying directly to the gap with the supplied red nozzle/tubing drove the cleaning solvent into the internal contacts quite effectively. Be sure to clean the PCB before spraying so that dust won't get into the contacts along with the solvent.
