Author Topic: Help me identify this pushbutton switch?  (Read 951 times)
Offline cvancTopic starter
« on: August 30, 2018, 02:23:51 am »
Photos attached.  It's from a handheld remote control.  Thanks in advance for any assistance you can offer - there's like a million of these to sort through.
Switch body is approx 11.8mm square and 3mm thick
Button is approx 7mm diameter & 5.5mm tall
PC pin spacing is approx 5mm
SPST push-to-close (ah, if only these would close!  They're crap, totally intermittent)
Offline floobydust
Re: Help me identify this pushbutton switch?
« Reply #1 on: August 30, 2018, 05:02:21 am »
The original "parent" is the Omron B3F series tactile switch. The chinese have copied them and made it a generic with many different plungers built-in, instead of Omron's approach which requires additional buttons.
There are two (base) sizes, 6x6mm and 12x12mm. Plungers come in 0.5mm increments.
I think you have a 12x12mm, H=5.5mm plunger (or 6mm), through-hole part.
Search fleabay or ali for 12x12 tactile and you will find them.
The following users thanked this post: cvanc
Offline Nusa
« Reply #2 on: August 30, 2018, 05:17:07 am »
Note that the specified height usually includes both base and button, but not the pins. So the size you want is probably 12x12x8.5 or 12x12x9. Measure your existing switch as a whole...eliminates rounding errors on separate measurements at least.
« Reply #3 on: August 30, 2018, 12:53:26 pm »
Thanks, with the right search terms I'm finding lots of them.  Much appreciated.
