I pick up a TV from the garbage. At first, I turn it on, the LED green light is on, blink for 9 time. There is no sound, no picture, no backlight, I use a flashlight, there is tv manual image at the dark panel. It is strange that there is a resistor weld at the LED driver board (shown at photo). There is red light on the Main board Digital Audio Out when the TV is turn on. From the shopjimmy.com youtube video, it is most likely the LED driver board but it is strange that there is a resistor welded.
I tried to do a voltage test from the shopjimmy.com reference video
Between the Power Supply Board to the Main board, I think I have accidentally short circuit the 2nd and 3rd pin on the Power Supply Board to the Main board 2nd pin. There is a spark on the 3rd pin of the Power Supply Board during the short circuit. Now there is no sound, no picture, no backlight, no start LED light, no red light on the Main board Digital Audio Out.
Can you advise me what test I can do before decide which board to replace. I'm not a professional, if you can provide the instruction to test what is spoilt during the short circuit, eg diode, capacitor.. I have a Fluke 175 multimeter to test. Below are the board part number. I provide some reference photos. Please let me know if I need to provide more photos. Thank you.
LED Driver Board
L390H1-1EE
Power Supply Board
TNP4G532
Main Board
TNP4G530
