Author Topic: testing help  (Read 952 times)
Offline skumarTopic starter
  • Country: in
testing help
« on: April 19, 2019, 06:51:33 am »
Sir i need help
i connected smps, AC-DC- output was 5v 0.5 A, but all mcbs tripped of household, even whole my swtich burned  :phew:
how to do protection and set up testing lab for these if i take 2A
do i need to conNect MCB or wht
plz help
Offline anewmanx
Re: testing help
« Reply #1 on: April 19, 2019, 08:21:43 am »
I’m not sure I fully understand what you are asking. It sounds like your power supply has a dead short. You could make a dim bulb tester to act as a current limiter and then try to find the short, especially if you can bring it up slowly on a variac. A safer bet would be to try to find it with a multimeter first. Your most likely culprit will be an electrolytic capacitor that is shorted internally. Likely you have damaged components now.
  • Country: in
Re: testing help
« Reply #2 on: April 19, 2019, 08:28:46 am »
ok thanks
I also want to know what is the basic of testing, like i m afraid if i  testing 100 w or 2 kw ,   have seen people in lab use MCB as protection
So how should i set up testing wiring, for whether 100w or 5 kw
Sir ,, now my question what should be protection in lab if i just conect input output for high power,(  not asking how to test), asking protection sir
« Last Edit: April 19, 2019, 10:42:23 am by skumar »
Offline PKTKS
  • Country: br
Re: testing help
« Reply #3 on: April 19, 2019, 01:54:02 pm »
The TIP of a BULB DIM is indeed a GOLDEN RULE.
Don't  - JUST DON'T - TURN ON A FAULTY DEVICE WITHOUT A DIM BULB
The POWER is also very important - use a SET OF BULBs - which the SUM
is equivalent to the power of DUT - e.g. the BULBs power is equal to the
device power.
Put the DIMs in series with the line of the device and try to turn it on
it the bulb lits the device is dead shorted.
In this case to proceed is very handy a VARIAC as well
Paul
  • Country: in
Re: testing help
« Reply #4 on: April 19, 2019, 02:47:18 pm »
ok thanks
