Sorry for the late reply, i had some issues with using the phone as a signal generator. My new generator has now turned up so i can carry on with the testing.
I have removed the IC201 (TC9164N input selector) and wired in the generator at 10000Hz stright into the output pins 9 and 23. I found a dry joint at R302 right channel which I have sorted. The amp will now pass the signal through to the output speakers both channels with volume control. So it looks like the power amp and tone controls all work ok.
I checked the DATA, CK, ST signals to the chip and I was getting the following.
DATA - 1 pulse different width for each selection
CK - different number of pulses for each selection
ST - NOTHING
So checking the front CPU the ST was pulsing one pulse each selection. I found another broken track next the the CK track which was also broken.
This is where i am at the moment. I have repaired all tracks and have the DATA, CK, ST signal at IC201 with the chip removed.
With the chip back in i then get a lot ac noise on the data signals and with no signal inputs connected.
playing music through the amp it plays very well no hum and I have all tone/volume controls
When selecting other inputs the amp still does not change channels but has a click on the speakers each time a channel is select
This is the second selector chip fitted and still I have no selection of the inputs. The noise on the data lines may be an issue. I have an ESR tester on the way so I can test all the caps to see if they are failing.
I am also thinking setting up an arduino to test these chips see if they are failing from supplier or failing when fitted.
Below is another link to the manual through my google drive let me know if this does not work.
https://drive.google.com/file/d/1o9IBB3qA9oTIFPELvhgNkEvBqX7wqp0A/view?usp=sharing
