Where does the upper end go to?
A square inch of PCB is not much to go on, but, it looks like the resistors are in parallel and possibly connect to what looks like the output of an amplifier - so does the other end of the pair go to the output BNC ? If it does I would say there is a good chance that they are 100
each - giving you a 50
output impedance. And they've probably been damaged by power being shoved back-up the output!
Another photo with a slightly larger view of the PCB, same ligthing, may be useful. Also a photo of the same area on the reverse side of the PCB.
