Have you built the console port adapter yet?
Hi Denimdragon
Sorry for Off Topic , but i dont know schematics or diagrams to build TDS Console Port, All topic in tek forum have change url and die . If you know how to build console adapter port pls guide me .
Thank you so much !
Nam Nguyen Hai
Option 13 refers to the RS232 centronic board at the back of the TDS unit.
The objective is to connect this board to the A11 processor board J40. [by jumper wires or by pcb adapters]
On the TDS520, the console port is J40, a PCB edge connector 10 X 2 [See pictures].
The correct pinout is as follows;
Console port - Option 13 Board - (Signal Name)
A10 - 1 - (D24)
B10 - 3 - (D25)
A9 - 5 - (D26)
B9 - 7 - (D27)
B8 - 2 - (D28)
A7 - 4 - (D29)
B7 - 6 - (D30)
A6 - 8 - (D31)
B1 - 21 - (A1)
A1 - 23 - (A2)
B2 - 25 - (A3)
A2 - 22 - (A4)
+5V (B6) - 24 - (A5)
GND (A3/A8) - 26 - (A6)
B5 - 12 - (INT#)
B4 - 15 - (IOCS#)
A5 - 16 - (SYSRESET#)
A4 - 17 - (RNW)
A3, A8 - 9, 13, 19 - (GND)
B6 - 10, 20 - (+5V)
B3 - not connected
not connected - 11 - (DS#)
not connected - 14 - (DSACK0#)
not connected - 18 - (AS#)
Notes:
On the console port "B" is the top side of the processor board.
Signals A5 (Pin 24) and A6 (Pin 26) need to be set to +5V and Gnd to make sure the serial port of the option 13 board is selected.
The 3 ground pins (9, 13, 19) should be connected on the option 13 board, so normally you only need to connect one of these to the console port connector.
The 2 +5V pins (10, 20) should be connected on the option 13 board, so normally you only need to connect one of these to the console port connector.
This link below provides exact information from the contributors there. Also PCB adapter board designed by someone.
Take a look;
https://forum.tek.com/viewtopic.php?t=137307&start=20I hope this compile give you a proper direction/starter to building the console service adapter.
