Hello everyone, I buy this Tek scope locally for about 50 USD, it was working but have 2 main problems, besides some minor mechanicals issues with the case and 1 missing knob wich I'll fix easily I guess.
+ The first obvius problem is the display, looks way discolored and weird, I took several pictures of it in diferents contrast settings.
+ The second issue is with ch1 input, when I checked probe compensation, it measures a 1 Khz signal, but with the waveform showed in the pic below, I suspect some kind of open component in the signal path, since the waveform look like a capacitive coupling and measures 1 kHz with precision, I took pictures with AC and DC coupling setting and the waveform looks the same, in GND coupling the waveform goes to 0 as expected, the problem is with CH1 since CH2 works without a problem showing a nice and sharp 5V@1Khz waveform. The self test pass with no errors.
Now, regarding the first problem, I took a picture from above since a screw is missing and you can see partially inside, and the CCFL is emitting an orange light.
I was wondering :
a - if the weird look on the display can be fixed changing the CCFL backlight or replacing it with one of those LED kits
b - If it's due some degradation of the LCD itself and has nothing to do with the backlight, because I noticed the LCD modules are quite pricey (and I can't afford those right now, and I guess I can live with that weird look) if this is the case, if anyone can recomend a hack (Display addapt of some sort) or a vendor with better prices, that would be awesome.
c - Has something to do with some fault at the CCFL driver in the PSU board.
I was also wondering if I can put a CCFL backlight I have from a TDS 220, I haven't checked, but I guess I can directly replace them?
In case no one noticed, I have 0 experience with displays.
Here are some more pics at different settings:
0% contrast50% contrast100 % contrastI must add, the weird orange light on the screen corners that the pictures shows, are somehow magnified, because I can barely see them outside the camera.
For the second issue, I want to open the scope this weekend and troubleshoot the front end, I believe It could be an easy fix, but I wanted to post it in case somebody has a similar issue and can provide assitance, here are the pics regarding this issue:
Weird waveform measuring 1 kHz ~ 400 mV spike , AC couplingSame with CC couplingGND couplingI'll post some updates when I open and see the guts of this scope, I intend it to use as my main scope since in my country is prohibitive to buy a decent test equipment, (I am building a workshop step by step, but is really hard, no ebay, no spare parts, no nothing, everything local ) and with all the issues, I consider it a win.
Excuse my weird spelling, I am probably one of the few (if not the only) Cuban viewer of EEVblog and EEVblogForum users. Thanks in advance
