My main computer doesn't have Bluetooth, but I tried on a laptop and it doesn't show up on there in the list of Bluetooth devices. I've tried another cable and it makes no difference. I don't have Resolve installed on the laptop, but if I plug it in to the laptop, Windows won't detect it.
Also the reset command hasn't done anything. It seems completely dead.
Swake: I'm glad you managed to find the relevant part of the manual. I was wondering where it was. TBH it is a very well written manual; I am coming from a Kdenlive background, which usually involves lots of trial and error, and googling, so having a proper [up to date] manual is very good.
Interestingly, the manual says the Speed Editor board will only work with USB3. When it was working the other week I had it hooked up to a USB2 port with a C to A cable which only had the usual 4 pins (5v, GND, D+, D-).
I'll contact the supplier and get it replaced. I figured it was worth a forum topic in case I was missing anything obvious, or in case anyone has a similar problem in the future.
