Here are the photos.
siglent sent me a revised board photo and they said L5 was a 1ohm resistor.
The resistor I pulled out of my faulty board tested at 5.5kohm
That is weird because that resistor is the bridge for the positive rail that comes from the SMPS mains and feeds the inverter and the only thing that could have fused it would be a fault with the inverter transformer drawing too much current or a shorted bypass cap...
So my suspicion is the resistor got overloaded, fused, damaged the board and damaged got it conductivity reduced. Does that make sense?
If that is the case, the inverter block is drawing too much current and will fry any other resistor I put in there unless I raise it is power ratio, but then that will stress something on the SMPS block...
I am also not sure why placing a resistor there instead of a fuse. If you look at the silkscreen it was supposed to be a fuse there and that would probably have avoided trashing the PCB.
what are your toughts?
