good point. I did measure some comps that have drifted (such as the 22Mohm that is now 25Mohm). I don't want to continue to pay multiple shipping charges since I now know that I am going to need a variety of parts (of which I will definitely be buying a bit extra!!!) so I am replacing what I have replacements for or that are bad enough for me to make do with what I've got. Noting them and adding them to the order list.
I did notice that using metal film instead of comp for those 470K inputs isn't going to be working out. The signal is clean before those, but directly following them the peaks are slanted. Maybe it's the higher voltage caps, the resistors, or the combo, but I can tell that the RC is causing overshoot on the rises and falls. I just hope that the caps I find for replacements work well, otherwise I will be trying again since it's a critical part. If the input signal is wrong, everything is going to be wrong.
It's incredible how many of those little MLCC's are bad.. I replaced all of the tantalums - dipped, 173Ds, 150Ds, and all of the small electros, so I won't have those to deal with. Following all that, I noticed a tremendous drop in the amount of heat on the transfo and rectifiers - and also various components throughout.
I guess there is a reason why almost every single resistor that the manual specifies as comp have been replaced with metal film?
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
It appears that someone has systematically went thru and replaced them all at once.. the soldering is professional, so I guess I should keep to that and where there is currently a film resistor, and it needs to be replaced, replace it with another film?
