Hi All,
I have a switch mode power supply that has 2 sections. One for standby mode which puts out 5v, and activates a relay when it receives the standby singal, which activates the 2nd section (now fully working). When the PSU is plugged into the equipment and the equipment is turned on the 5v line drops as soon as the power button is released to 3V. This causes the light on the equipment to go from orange (standby) to blue (on) very briefly, to off, then back to standby.
I've meassured the current draw on the 5v line. When the unit is turned on there is an inrush of around 20mA. Then it settles down to less than 1mA. When I press the power button it jumps up to only 20mA (using DMM and min max function). I guess it could be much higher and I'm just not able to capture it. If I attach a 220 Ohm resistor load to the output to give it a tiny load it of course does not fluctuate at all.
Attached is the schematic. A trace of the 5v line and pin 8 of the transformer during the brownout. You can see the frequency change on pin 8 just before the voltage drops. Then there is pin 8 of the transformer at the moment the frequency changes and finally pin 8 of the transformer showing it at a steady 5v. If anyone has any ideas I'd really appreciate it.
