This is a quite primitive instrument.
Although RCA were still trying to flog it off in the late 1960s,it is pretty much the sort of design you would
have found in the late 1940s as far as the triggering facilities,etc.
It did have better maximum bandwidth than a '40s 'scope,though,at 4.5MHz for low level signals & 1.2MHz for high level.
There isn't any real "triggering" as in more sophisticated Oscilloscopes-----you set the timebase to "free-run".&
adjusted the "sync" control,till it hopefully "locked".
A contemporary of this unit was the Telequipment "Serviscope",which had 10MHz bandwidth,& real triggering,although it did use a smaller CRT.
RCA were really trying to get as many sales out of an obsolete design as they could!
All that said,if you want to fix it up "for the fun of it",there is nothing wrong with that.
It is still a usable instrument,providing you understand its (quite substantial) limitations.
