Re-cap the power supply, I have done some videos on this unit.
Mine also had issues with Tantalum caps failing (because of the main power supply ripple getting excessive), so you may want to get onto that sooner rather than later.
A point to note, if you power it up without the cover on make sure you have a fan blowing air across the hybrid modules... you don't want them to overheat and blow up.
