Author Topic: Tektronix 2232 Repair Help  (Read 1710 times)
Offline TrooperNTopic starter
« on: March 20, 2021, 09:31:37 pm »
Hello, I recently got a Tektronix 2232 with a interesting issue, the trace is very thick about 2 inches, the volts/div is working correctly so is the time base and triggering, if I feed a signal in it is displayed correctly but the trace is still very thick, both channels are having the same issue. I have measured all of the voltages coming out of the power supply, here is what I got:
+100v = 102.0v
+30v = 30.0v
+8.6v = 8.50v
-8.6v = -8.47v
+5v = 5.30v
-5v = -5.69v
I have also noticed high heat coming from RT901 and RT905 and the vertical amplifier and preamplifier. Also when it is turned off all of the power rails go to 0v except for the -5v rail which slowly drains to 0v.
Here is the service manual for my instrument (there are two different ones): https://archive.org/details/tektronix_2232_Service_Manual/
Any help would be greatly appreciated!
« Last Edit: March 20, 2021, 10:02:27 pm by TrooperN »
Offline grumpydoc
Re: Tektronix 2232 Repair Help
« Reply #1 on: March 20, 2021, 10:14:07 pm »
Switching frequencies superimposed on trace?
Check ripple and all caps in the PSU
« Reply #2 on: March 20, 2021, 10:26:58 pm »
The focus control does not seem to change anything
Offline bdunham7
« Reply #3 on: March 20, 2021, 11:00:36 pm »
If you look in your manual for the schematic page that shows the CRT and DC Restorer circuits, you will see a string of 510K resistors with the focus pot in parallel with one of them.  There will be one 180K resistor as well.  Check all of those resistors with an ohmmeter (power off for a few minutes first...) and you will likely find that some or all of them are higher than they should be.  If so, replace them all with an improved HV resistor.  I use Vishay HVR37 for the 510K and HVR25 for the 180K.  It's a common issue.
The following users thanked this post: grumpydoc, TrooperN
« Reply #4 on: March 20, 2021, 11:05:40 pm »
They all seem to be out by about 10 to 20k could that still be an issue?
« Last Edit: March 20, 2021, 11:07:20 pm by TrooperN »
Offline bdunham7
« Reply #5 on: March 20, 2021, 11:30:20 pm »
No, not if they are that close.
What do you get in XY mode with both inputs set to GND?  (Non-storage mode, of course...)
« Reply #6 on: March 20, 2021, 11:38:11 pm »
I get a box the height of the trace and about 1cm in width
« Last Edit: March 20, 2021, 11:41:18 pm by TrooperN »
« Reply #7 on: March 20, 2021, 11:49:05 pm »
Also when re-measuring those resistors it seems R890 is completely open or too much resistance for my multimeter...
Offline bdunham7
« Reply #8 on: March 20, 2021, 11:54:23 pm »
Does the focus knob have any effect on the sharpness of the edges of that rectangle?
If any of those resistors are significantly high or open, they should be replaced en masse before you go further.  If you confirm that the one is open, you can swap in another 510K of almost any time just to see how the rest of the scope works.
« Reply #9 on: March 21, 2021, 12:36:52 am »
I was unable to find a 510k one but I found a 485k one which should work?
Offline bdunham7
« Reply #10 on: March 21, 2021, 12:41:08 am »
Close enough to test with.
« Reply #11 on: March 21, 2021, 01:14:24 am »
Got the resistor replace, that was the problem! However I noticed some back and forth wave thing in the trace...
« Last Edit: March 21, 2021, 01:17:56 am by TrooperN »
Offline josh132
  • OSCILLOSCOPE
« Reply #12 on: March 21, 2021, 10:05:52 pm »
That wave thing is likely power supply noise. Try adding higher capacitance caps to the out put rail. Or maybe one of the caps are dead and are not effectively filtering power supply noise. A tek 2235 had a similar problem and all that had to be done was add higher capacitance caps that are build to filter supply noise.
bu du bu nu
Offline Mike P
« Reply #13 on: March 22, 2021, 08:28:33 am »
I had the same issue with the string of resistors in the focus adjustment on my 2235. I replaced them the first time with carbon comps (as original) and after a couple of years the problem reoccurred. The second time I replaced them with higher wattage metal films and it's been good since.
« Reply #14 on: March 22, 2021, 09:31:37 pm »
The issue was R980 for the focus control, I might look into re-capping the power supply. Also I think the wave in the trace went away after reinstalling the digital board.
