Alright. Spent some more time on the pre-reg board. I did all the checking I could do with the DMM, before I resort to firing up a scope to check waveform.
Checked all the passives, lifting a leg here and there when needed, to get a reliable measurement.
- All small signal transistors check OK (I pulled them to be 100% sure...)
- All 3 electrolytic caps measure fine and don't leak, but no idea about ESR since I don't an ESR meter just yet. Soon hopefully, though.
However for the kind of symptoms I see, I don't see how a high ESR could explain it. So I will replace them for good measure and preventative maintenance, because they are bound to go bad later on (scope is 36 year old already...), but I don't expect it would make any difference for the problem at hand.
- The 4 tiny caps around the PWM chip, come in a funky packages. 3 of them come in dipped bright green axial packages, and two come in a transparent glass package with red terminals, making them look disturbingly like an old Germanium diode !
However I was not too shocked, because I learned about their existence of such packages for caps, from a gray beard who designed crystal oscillator prototypes in the 70's. These glass dielectric caps had the advantage of very high temperature stability, IIRC, which was critical in getting the oscillator to be as accurate/stable as possible, which was his goal back then.
Anyway one of these green caps broke in two when I lifted one of its legs... was gentle I swear. So I guess this cap was just waiting to fail anyway. That was C929. Then the two remaining green caps (C925 and C920) don't instill a lot of confidence either : I lifted a leg on both them, yet the DMM wouldn't register anything, display was stuck to 00.00nF, didn't budge. That means these caps are.. open. So all of these green caps will be replaced.
Trap : in the pictures, you can see not 3 but 4 of these small green packages... one of them is NOT a cap, but a precision/ 1% resistor ! Go figure... never seen a resistor packages like this. Also, the accompanying resistor (other leg of the voltage divided that sets the output voltage, R921/R922), comes in a "normal package. So it's not consistent...
- R937 reads a bit high at 8.75K for a nominal 8.3K 5%. However I do'nt think it matters at all, given it's purpose on the board. It's in parallel with the filter cap on the output of the regulator. Not even sure what it's for... The output being at 43V, is above the usual "safety" level, 24V IIRC (my meter gives a warning above 24V anyway). So maybe the resistor is meant as a bleed resistor for the capacitor. However I don't see the point of it since the regulator board is supposed to be permanently wired to the inverter, which draws 750mA or so... which would bleed that capacitor real quick anyway...
However if Tek really cared about safety and bleeding capacitors... I would have found it much more important and logical, to bleed the high voltage cap that rectifies the mains : 320Vdc ! But they is no bleeder there... I timed it, takes quite some time for the cap to discharge, over 30s.
Other hypothesis : that resistor is there to ensure a minimal load on the regulator, for it to work properly. That wouldn't be uncommon. However, again... the inverter it supplies is plenty enough of a load. So, this dummy load would be of any use only when a service tech disconnects the inverter to trouble shoot the SMPS... just like what I am doing right now. IF so.. how thoughtful from you , Tek ! Thank you.
- R911 reads really too high : 180K for a nominal 150K. Sure it's not a precision item, just the common 5% type. However even at 5%, the maximum value would be 157,5K ... and I measured like 180K. I am not too sure what kind of impact that would have on my symptoms though, but at least it's worth keep it in mind... Oh, this resistor as you can see is the beefy 1Watt thing that feeds the 320Vdc to the circuitry that powers the PWM chip.
- Checked the switching coil/transformer / T933. As I suspected, and hoped, it is just fine, hooray. All 4 coils in it, are neither open nor shorted. They all read plausible values, in tune with what I measured on the similar tranny in my 2232 scope. So that's a big relied indeed !
After I had checked all that, I resoldered all the legs I had lifted, reflowed a few solder joints for good measure, then powered the thing back up to see if it somehow made any difference. Did not. As I expected, all the green caps, which I removed because either broken or reading open, didn't impact the symptoms the slightest bit : we still have 13+ on the output, and only 2,8V for the PWM chip power supply instead of 14V...
So I then removed the PWM chip itself (and soldered a chip socket in its place while I was at it), just to see if it might be defective and load it's power supply too much, to the point of dropping it from 14V down to the 2,8V I was seeing. Without the chip, the supply goes back to 10,7 V or so, much better, but still not the expected 14V ! But this time the PWM chip can't be blamed.. so the problem must lie elsewhere... in the circuitry that's in charge of generating that 14V to begin with. I highlighted that circuitry in the schematics below. Also attached, the 3 pages of text that describe the operation of the pre-reg, including this little circuitry.
Basically you have C913, 100uf electrolytic, which powers up the PWM chip. At power up, it progressively gets charged by the rectified mains, through R911, that 1W 150K resistor that I just discussed above, which reads 180K instead of 150K...
Once the voltage across that cap reached 14V, the circuitry then regulates it at this value (by means of transistor Q917 and a Zener diode VR917) and sends this juice to the PWM chip power pin (#12) using transistor Q915.
So, I measured the voltage drop across the Zener diode, which is a 6,2V one... got 2+ volts IIRC, don't quote me on this, which didn't make sense to me.
The Zener tested fine with the DMM, in the forward direction. Obviously I could not test it in reverse bias.
So since I was still looking for leads on this repair... I bit the bullet and pulled that Zener so I can test/characterize it properly, on a bread board.
10K in series, reversed biased of course, then ramped up the voltage progressively with the bench power supply. What I witnessed was most strange.. the Zener is definitely bad, and sure enough the circuitry can't work properly with this things in it !
Now I have no particular knowledge or possible failure modes for Zener diodes, other that that common to any PN junction : either shorted or open...
So this is what happened on the bread board... two problems at once :
1) It's a 6,2V Zener, but somehow the "knee" drifted dramatically : it starts to conduct at a much lower voltage : 2Volts or there about !
2) Once it starts conducting, hence we have passed the knee... there is another problem : it still does not regulate anything : the voltage across it keeps rising and rising, somewhat linearly. In other words, it's dynamic impedance has increased dramatically ! It does not "regulate" anything anymore.
So that was quite interesting to me, this scope repair was worth doing for seeing/learning these failure modes in Zener diodes...
I had a few Zener diodes in my drawers (sadly no 6,2V nor any values that I could combine/put in series to add up to 6,2V), new, but about the same age as the scope or almost. 25 years at the very least, or shy of 30.
So I was curious to test them all, see if I just got unlucky on the Tek scope, or if there was a pattern there...
I was not disappointed : had of old new Zener diodes showed the exact same issues !!!
So there you go : it's definitely not uncommon, it was not just bad luck.. this a definite failure mode for these things !
Not sure how relevant it is, but I also noticed something : out of all my new Zener diodes, only the low voltage ones were affected. Those rated at under 10V.
I had 3,3V ones, and 4,7V. Then I had 12V, 15V and 25V.
Might just be a coincidence.. but maybe not, because there is a pattern : I had around half a dozen diodes of each value. I tested 100% of them. I noticed that 100% of the low voltage showed this issue, and absolutely NONE of the "high" voltage ones did.
To finish up with the Zener : I figured the black coating on their leads : it's a fine oxidization layer, easily scrapped off. Only the Zener diodes on this board have this... I guess their leads must be made from a different material than all the other components...
So with a 6,2V Zener that starts conducting at 2V or about, and which is unable to regulate anything, no wonder it doesn't work.
There is still a bit of mystery as to how I can measure 13+ Volts at the output of the regulator, when the PWM circuitry puts out on ly 10+ V ....
Maybe the tow voltage levels are unrelated then. The only path I see for juice to get to the output while bypassing the PWM circuitry, is via the FET.. so maybe it conducted a little bit even though it is not driven. So might still be faulty in some way, just maybe. I will pull it to see if the output drops to zero. Ought to.
OK so that's it for today.
I will now order a few components to be able to go further :
- Zener diode, hoping it would cure the problem
- Replacements for all the 3 tiny green caps that either open bad or broken in two...
- New electrolytic caps, for preventative maintenance
- New R911, 150K 1W high voltage resistor in case it reading 20% too high maybe part of the problem, along with the Zener.
- And just in case : a new PWM chip and FET, so I don't have to pay shipping twice just to get hose if I do happen to need them.
Sadly the parts list, maybe because it's related to a revision change and not the main/original parts list... does not give enough technical detail to be able to order a replacement part : just says "N-Channel MOSFET" .. great, how helpful ! So I can't check whether the FET in place is the correct one (might have been replaced and be part of the problem..). But well, I will just go buy the info in my 2232 part list. IIRC the FET is not critical, back then we found several possible modern replacement. Hell I might still have some spare/new FET's from that 2232 repair, that I could re-use in that 2215... need to check my "archive" box...
- Might also recap the main board, to be consistent : the inverter and the secondaries.
Oh ! Forgot a nice thing : the non-working delayed time base I noticed during my quick test ride... works just fine in fact : it's just that always.... I forgot that to for ti ti work/display the trace, you need to get to the "B Trigger level" knob in the upper right corner of the front panel, and cranck it all the way CW, in the "run only after daily" position... Works much better now ! Operator error, hum hum..
Some attachments and off to bed :
- Principle of operation of that regulator board
- Board layout of the board
- Overall schematic for the SMPS, which of course includes the regulator board, which occupies half of the schematic just by itself...
- Annotated Schematic of the regulator, highlighting my main focus : the circuitry responsible for providing the 14V to the PWM chip.. which we need to get working.
