Hello, new member here, I was wondering if I could get some assistance in repairing my Tektronix 2465A scope. I'm afraid this is a bit out of my knowledge base.
I was using the scope one night, and after about 30 minutes of runtime I heard some crackling and saw all the magic smoke escape. Opening it up I found some crusty caps in the power supply and a burnt resistor. I'm in the process of ordering the visually damaged and suspect components, but is there any other service type work I should also do? I've seen a post or two about shotgun re-capping the whole thing, I wasn't sure if that was really necessary. Any recommendations would be greatly appreciated, this is my first time working on test equipment.
