Most levelng head problems that I have seen are due to contact issues with the relays. The relays consist of a top part (head) that is screwed to the PCB. It includes the magnets and a leaf spring contact on a pivot. The contacts touch pads on the PCB. Remove the relay heads, inspect and clean (VERY carefully) the leaf springs, and clean the PCB pads.
