Author Topic: Tek P6248 cable repair  (Read 1178 times)
Offline SBWTopic starter
« on: August 27, 2018, 05:16:36 am »
I have a Tek P6248 differential probe that seems to have had its cable yanked.   Three of the wires have broken off their pins at the connector on the back of the probe.  My problem is that I do not know which goes where.  Looking at the back of the connector (solder cup side, not mating side) I have:
Coax signal  Coax shield
Purple          Black
?                  Red
The broken wires are brown, white, and blue.
The 'red' wire is more orange than red, but there is also a loose orange wire that I suspect is a NC.
Given the lack of strain relief on the cable, and the fact that the P6248 I borrowed from a friend also seems to have similar damage, it seems likely that this is a common problem.  But not so common that I was able to find the pinout, or enough schematic information to deduce the pinout.
Can anyone tell me which wire goes where?
Thank you,
Steve
Offline tautech
Re: Tek P6248 cable repair
« Reply #1 on: August 27, 2018, 05:25:58 am »
Welcome to the forum.
This may or may not help:
Tek Probe Circuits ~19Mb
http://w140.com/tekwiki/images/6/62/062-1146-00.pdf
P91-
It's old but could point you in the right direction.
« Last Edit: August 27, 2018, 05:36:20 am by tautech »
Offline Haitarai
  • Country: as
« Reply #2 on: August 27, 2018, 07:01:20 am »
I'm looking for this information to fit it.
Offline KrudyZ
« Reply #3 on: August 27, 2018, 11:23:32 am »
Here you go!
I hope that's the side you're interested in. I don't really feel like unsoldering the shielded case of the probe itself to peek inside...
« Last Edit: August 27, 2018, 11:26:11 am by KrudyZ »
