hi guys,
i got me a philips cdi, IR sensor is not working and the cd drive but i will take on this later on.
when i first plug the cdi in and power it up, the console did boot and i got to the main menu. then after a couple of minutes i switched it off and back on again, now i get only blackscreen( tv did flicker on switch on, so something must happening). i then let the cdi get cold and it worked again, after power cycle black screen again.
i tryed testing the output voltages of the psu but i only got 0.14V. this error must be on my side, philips service manuals are not my friend
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
i have it appart now the psu has some heat damage where the big resistor is solderd in, there was also a lot of gung on the pcb. on the undersite i notice the solder of the main filter cap did look wierd, like melted in some way. i desoldered the cap and i think it did leak fluid and the cap is AOE branded, the others are all matsushita.
what components should i repair/check?
thanks for your advice daniel
