I have had thermal fuses open from current surges but that's a very expensive custom trafo so if your gonna do the job be EXTREMELY careful, I saw a post recently where some fool tried to open a trafo by slashing it with a knife and completely destroyed it! Think of it as open heart surgery!
It's most likely on the side with the primary wires. On that side very carefully peel back the copper (remember it has to be resoldered afterwards, then each layer of insulation (WITHOUT CUTTING ANY WINDING WIRES UNDER IT) cutting alternate sides so the cuts wont overlap when it is re-assembled. Keep following that 0V lead and if you are lucky you will find it jointed to a bare wire or something other than winding wire, that will be a lead of the cutout. Hopefully you can gently prise the cutout out of its enfolding layers of insulation and replace it (dont be tempted to just short it out).
Good luck
